I am building an assembly in SW 05 with about 100 mates. I have a planes defined in the assembly which I use to control the position of components.
For example, 3 parts are mated coincidental to Plane 1 using planes from the parts files. Plane 1 is positioned 10" from the orgin. If I change the position of Plane 1 to 11", then 2 of the 3 components also move. The 3rd component gives a mate error that states, "Planes not coincidental, 1.00 difference". Reloads do not fix the problem. I can fix the problem by editing the mate, but this is rather annoying.
This problem occurs everytime I move a positioning plane. Is this a bug in SW?
Any suggestions?
Nick
Any suggestions?
Nick
