Hi, planning to construct a pool on soil, that has low bearing capacity,mostly sandy soil and relatively with a high water table,like above 15 iinches from pool floor,walls and floor is determined to be 8 inches with two layer rebar at bottom and top, wall height like 5 feet,what can be done to improve subgrade soil to prevent settlement of pool, thinking of compacting grade soil after excavation, Is there anything I can do without fill in gravel, what to watch for to be sure the compaction will do the job,
