Mechmanshan
Hello, I am building a test stand where I need to be able to switch between solenoids. As it is now the system is set up with three on/off switches, to switch from one solenoid to another you would have to turn off one then turn on another. I would like to have it where when you turn on one switch it turns the others off, ideally only one solenoid would have power at any given moment I would also like to have a master switch than turns them all off.
Thank you in advance.
