123131415
- Nov 13, 2006
- 17
I am new to HVAC industry and assigned task to design air conditioning system for 33 KV substation wherein switch gear room has to be maintained positive pressure of 30Pa. Equipment heat gain is of 250kw and room to be maintained less than equal to 25C deg and RH of 75% max.my question is how much of air is required to maintained 30pa. is this pressure required to avoid the containments entering into the switchgear room if so than how it will be calculated. thank you
