Burunduk
- May 2, 2019
- 2,513
If a drawing references ASME Y14.5-2009 and specifies symmetry tolerance applied on a width feature with references to a cylindrical datum feature ( which imposes an axis as a datum) - was this supported or not?
Para. 7.7.2 clearly states:
"Symmetry is that condition where the median points of all opposed or correspondingly located elements of two or more feature surfaces are congruent with a
datum axis or center plane."
I used to think that the tolerance zone in such a case should be two parallel planes equally disposed about a datum axis and rotated about it until obtaining a best-fit orientation to include the median points of opposed elements of the actual feature surfaces.
However, ASME Y14.5.1M-1994 doesn't seem to provide a definition for how the median points should be derived in this case, because according to "TABLE 5-12 SYMMETRY PATTERNS FOR OBTAINING CORRESPONDING FEATURE ELEMENTS" The patterns of symmetry rays used to derive the median points (centroids) have to be:
"Rays from, and perpendicular to, the datum plane"
This seems to imply an ambiguous direction of rays when a datum axis is used. Is this another discrepancy between the standards?
