I believe that its possible to use the new CX-One programmer to communicate with the older PLCs. Its possible to get a time limited demo of the new software that will communicate with older units, but it stops working after a while (maybe a month?).
if you know what the firmware revision on the processor you should be able to determine the software used. Firmware is usually part of the part number tag.
