struclearner
- May 8, 2010
- 122
The Tap Bolt Joint has threads in the lower member of the joint and usually the hole is not a through all (a blind hole).
Is there a bolt joint with a member having a through all hole with internal threads and no nut.
Which bolt joint is better, i.e through bolt (with a nut) or a tap bolt (no nut) as the durability, retaining the clamping pressure and resistance to being loosening due to vibration loading.
Thanks for help.
Thanks for help.
