I have a rectangular duct about 1 meter wide, 1 meter high and 6 meters long, the duct is filled with columns of trays arranged horizontally, air flow enters the duct through an 8" pipe and exit through another pipe of the same size, I'd like to know the best technique to achieve almost uniform flow velocity everywhere around the trays, I've tried using diffusers of different sizes, but the velocity was always higher in the middle portion of the duct than at the trays near the bottom and top, I've also tried using perforated plates, straightener packs, but those resulted in higher velocities near the walls than at the center, they also induced vortices immediately downstream at the middle portion, when I used both techniques simultaneously, I got better results, but still had considerably lower velocities at the trays located midway between the center and the top and bottom, I used Ansys Fluent to test these techniques.
