Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
electricpete said:1 - More permanently installed vibration sensors on some critical equipment. Battery powered accelerometers with wireless connectivity are cheap/easy to install. Can give more data with less manpower than manual data collection. And if installed at inaccessible locations (below grade on vertical pump column), it gives you access the measurement points you couldn't see before.
2 - Motion Amplification (computer processing of specially collected video). Ideally it's an instant operating deflection shape analysis (at each frequency). In practice it takes a little work to capture and analyse.
