YungPlantEng
Chemical
- Jan 19, 2022
- 84
We’ve had issues on a vessel chasing the weld with crack propagation originally induced through chloride attack. This vessel is a POS and we’re sourcing a replacement. There is also deep pitting observed on the vessel. All of this is a result of CUI.
Since we don’t appear to have any luck welding on it, would we be able to utilize a resin and carbon fiber wrap either internally or externally on the vessel? This vessel is not run at high pressures currently - maybe 9 psig max although it’s rated to 40 psi. And we can be assured that the polymer/liner/resin used would be acceptable for service due to the manufacturer designing our other lined tanks.
From my understanding NBIC doesn’t cover temporary repairs. Would we just use the relevant ASME code or is a cowboy patch like this just blatantly illegal? We’re working alongside a contractor with R-stamped welders and two different AIs who recommended the idea but don’t seem to have a breadth of experience with this to be honest.
