plausibly_civil
I'm designing a repair procedure for some deteriorated joists in an apartment building, and need to provide a shoring design for construction. It is a wood framed floor and has (2) layers of gypsum ceiling below, which will not be disturbed. The repair procedure is all done from above so that the units and corridor below are undisturbed during construction except for temporary shoring. I haven't done much temp shoring design so I'm trying to get a handle on the design criteria for this task. The current capacity of the joists is unknown since they have some damage to the top of the section, but the construction load case is less than half of the service load case. Should I be concerned about anything other than limiting deflection to L/240 to prevent ceiling cracking? I haven't found many resources for this kind of shoring design, so any tips/design guides would be much appreciated.
