Tensile strength of thread connection 1
Hanson Gill_1983
IN
Please can someone tell me how to find the tensile strength or tensile rating in lbf of the connections below.
3-1/2" TUBING 12.95 PPF, TENARIS HYDRIL 533 connection
3-1/2" TUBING 15.8 PPF, NKEL connection
3-1/2" TUBING 12.7 PPF, JFE BEAR connection
Is it tensile strength in psi x area of the thread section?
Any formulas or guidance would help.Thanks
Make five of each type and go to a materials test lab.
Break all five in tension and take the average figure.
Suggest that you use 20 to 40% of this average in design.
I don't know why you would want to do this ..... It is not required by any of the piping codes that I am aware of ...but,
I am assuming that the Client's 20-something newbie engineer thought it might be a great idea ....
I assume that you are interested in testing these joints in the non-pressurized conditions... Right ?
MJCronin
Sr. Process Engineer
Don't these joints have load ratings?
Of course the rating for these would be axial load along with an internal pressure.
How to find out?
1) Look up the website of each of these bespoke connectors
2) If it doesn't tell you find a human on the contact us page
3) Buy three of each and then pull them apart as MJC says.
There is no formula AFAIK.
Five of each .....
MJCronin
Can't guess without pipe grade ; at least L-80 or you would not be using proprietary connections , but maybe Q 125 or even V 150. That is ;minimum yield between 80,000 and 150,000 psi.
Manufacturer's catalog or supplier's data sheets would be a good starting point.
