BENG_MENG_CENG
- May 31, 2022
- 3
Hi all,
I am looking at a theoretical problem to do with the formation of a basement in granular (dense gravels) the structure is proposed to be approximately 8m below ground level with a high water table at 1m below ground.
As the base of gravels is unproven in the problem a cut off wall is unlikely feasible and such de-watering or ground freezing would be required to allow a ground water free excavation in the temporary case.
In the permenant case however the uplift pressures will need to be resisted and it is not deemed economical to do this via the self-weight of the structure.
In this situation what are the potential options to resist uplift?
- Tension piles via skin friction, are these suitable in granular soils?
- Grouted anchors via engaging a wedge of granular soil, again are these suitable in granular soils?
- Other options?
Thanks.
- Other options?
Thanks.
