dik
- Apr 13, 2001
- 26,037
Can anyone recommend a relatively simple text on Tent Design? The tent is straight forward with no odd features. Ridge with pole support, eaves with pole support, and 'tension ties' anchoring it to the ground. I assume maximum loading is wind, maybe some rain... no snow, and maximum loading determines fabric required strength, max tension tie loading for rope? capacity Anything else that I should be looking at... did a bunch of stuff with Frei Otto's work about 50 years back on membrane/cable structures.
Dik
Dik
