RamiHabchi93
I am trying to understand how to determine the maximum allowable length of a building without expansion joint.
The problem is that I see,in case of contraction of a floor under thermal load,that we have to provide reinforcement for temperature what ever was the building dimension,with or without thermal joint,as the tensile stresses due temperature developes in the slab,even if they are small,cannot be resisted by concrete because it is cracked under flexure,so they need to be resisted by reinforcement.
I know that we provide shrinkage and temperature reinforcement always,but as a minimum reinforcement,not as additional to flexure.so when having flexure that requires reinforcement more than the minimum shrinkage and temperature reinforcement i see that we should always add thermal reinforcement.am I right?
