Hello all,
I have a two fold question about using coded and non coded vessels:
1. I understand that Texas and another state (which?) are the two states in the country where code vessels are not required. Most of the vessels (separators) I used are coded, but sometimes we don't use coded vessels on scrubbers and knockout drums. Is there a difference in manufacturing process in a code shop with a coded and non coded vessel?
2. As long as manufacturing process, corrosion allowance, etc. are good, if the state does not require coded vessels, are there serious disadvantages of having non code vessels? especially if there is no plan to re-use in another state?
As much as possible, do it right the first time...
