text fill
Juice
62
hello everyone
i just upgraded to acad 2000, and when i try to print the text is not filled in. Now, i know when i was in acad 14 there was a toggle in the print setup, is there one in 2000 that i am not seeing?
thanks
Juice
Have you tried "textfill" sys. var. set it to 1.
If you are using paper space, the plot dialog box has a hide check box. Uncheck this box. The properties "ctrl+1" box has a hide check box for the view port it self.Hope that this helps. Charles S. Parnell
Southern Store Fixtures
