text masking
zennis
63
Is there a way to make the express tool "text masking" associative, meaning if the command was used and then the text was moved, the masking will follow to the new location of the text.
Thanks for any help.
the text is already linked with the wipeout.
when you text mask, Acad creates a wipeout and makes an anonymous group (for the text and the wipeout)
"GR" @ command line
then check "object grouping" before you move the text
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
