Text Size
brunodg1
Hi all,
I am having trouble with altering my text size. When I modify my text size using the dimension style toolbox it remains the same size. So then I try to change it manually in the properties box and that will not change the size either? Does my version have some kind of voodoo spell on it or has anyone had this problem before?
brunodg1,
which version are you running?
Do you have a value in your "_style"? Change it to 0.
Lothar
ADT 2004
I actually resolved the problem. I am running AutoCAD 2002. I had to change the text style to STANDARD and then the dimension height changed to what I set the dimension style to be.
Thank you exxit!
