SBBlue
Automotive
- Oct 6, 2003
- 118
- 0
- 0
Someone on another thread mentioned the "Air Car" and gave a URL, which is:
I couldn't really figure how the air engine was supposed to work, so I did a google search and found this reference, appropriately enough at a website called "How stuff Works":
Now I'm not absolutely sure that what is discussed in URL #2 is the same as what is presented in URL #1, but the pictures of the cars sure look the same. I think they are the same device -- in spite of being referred to by different names.
Website #2 (How Stuff Works) gives the following information on the car, which runs on compressed gas;
Compressed air tank: 4351 psi pressure, 300 liters volume
Vehicle weight: 1543 pounds
Vehicle top speed: 60 mph
Vehicle range: 124 miles.
Doing some calculations with the standard air tables, it appears to me that the mass of air in the compressed air tank is 253.4 lbs, which means that if it is all used up over two hours, the average air mass flow rate will be about 2.1 lbs/min.
Making a couple of assumptions -- 1) the compressed air tank uses a big spring so the pressure stays at 4351 psi until the last ounce of air is used, and 2) we have a handy, dandy, 100% efficient compressed five stage air engine, and 3) we also have a heat exchanger so we can reheat the air as it expands from one stage to the next, the horsepower that the engine will develop is. . . . .
8.96 hp.
Maybe my calculations are wrong, but it appears to me that a 1500 pound vehicle might not be powered real well by a nine horsepower engine. Of course, once realistic efficiencies are considered it won't be nine horsepower -- it will be something more like 7 horsepower.
I did find one other URL that somewhat interesting:
It appears that the company has only three prototypes built so far, and the best range they have got with a full tank of air is. . . . .4.5 miles.
Anybody else heard of the air car?
Anybody have any comments?
8.96 hp.
