The right fitting extension
CanosSSCS
35
Hello all,
I am looking for a type of fitting that will allow me to slightly increase the length between a male fitting and thread, something like a bushing. I have a CPC to 3/8 NPT male fitting, and I need an adaptor of sorts that would go between the male and female mates. Preferable made out of brass. Fluid travels between the fittings. Any advice appreciate it.
Thanks.
What's the dimension of the gap need to be covered?
Sometimes, depending on the gap distance, it may be difficult to find the right fittings to make up the space for it. Instead, one may cut off some existing piece and remake it with right dimension.
Rputvin thank you for the link. This fitting/adapter is exactly what we are looking for, except the material has changed. We actually the same part in Al or SS. I've done some digging around but can only find the brass verison.
