Hussain2339
- Jun 4, 2021
- 59
The simulation, I am trying to bring about, is essentially related to a contact analysis between deformable and analytical rigid bodies, the interaction between them is defined by means of surface to surface contact type. The problem I have encountered is that the job gets aborted and the following errors pop up:
The CPSET or the surface parameter must be specified for history contact output.
The NSET parameter can only be used for bondstat or bondload output.
I would greatly appreciate if you can help me to debug the above error! Thanks a lot in advance!
