There is not enough memory for the Distributed Sparse Matrix Solver to proceed.
MarceloM
53
I'm doing an foot pressure analysis in Ansys with a insole and a suport (see picture pls).
The border conditions are very simple :
Top of tibia fibula and soft tissues = X=Y=Z=XR=YR=ZR=0
SUPORT= X=Y=XR=YR=ZR=0 Z=0,0004.
I have the following error:
*** ERROR *** CP = 156.875 TIME= 17:36:34
proceed. This is likely due to the use of pivoting while factoring
the matrix. Please increase the virtual memory on your system and/or
increase the work space memory and rerun the solver. Alternatively,
using the DSPOPTION command to switch to a different memory mode
and/or to specify additional memory for the solver may also help. The
memory currently allocated for the Distributed Sparse Matrix Solver
solver = 203 MB.
THANK YOU SO MUCH!!!
MORE INFORMATION:
FOR POSSIBLE RESUME FROM THIS POINT
THERE IS TOO MUCH PENETRATION AT 2222 CONTACT POINTS OF THE 3D CONTACT ELEMENTS
FORCE CONVERGENCE VALUE = 0.7870E+06 CRITERION= 0.5102E-04
VOLUME CONVERGENCE VALUE = 0.000 CRITERION= 0.1020E-05
DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
Number of equations = 214684, Maximum wavefront = 1729
*** NOTE *** CP = 127.203 TIME= 17:36:04
The initial memory allocation (-m) has been exceeded.
Supplemental memory allocations are being used.
Local memory allocated for solver = 687.594 MB
Local memory required for in-core solution = 483.191 MB
Local memory required for out-of-core solution = 200.383 MB
Total memory allocated for solver = 2786.367 MB
Total memory required for in-core solution = 1934.501 MB
Total memory required for out-of-core solution = 765.430 MB
*** NOTE *** CP = 127.844 TIME= 17:36:04
The Distributed Sparse Matrix Solver is currently running in the
in-core memory mode. This memory mode uses the most amount of memory
in order to avoid using the hard drive as much as possible, which most
often results in the fastest solution time. This mode is recommended
if enough physical memory is present to accommodate all of the solver
data.
*** WARNING *** CP = 127.844 TIME= 17:36:04
Pivoting has been activated for the Distributed Sparse Matrix Solver .
The memory required may greatly exceed the predicted amount. In that
event, use the DSPOPTION command to change the memory mode and/or
memory size used by the Distributed Sparse Matrix Solver.
curEqn= 39619 totEqn= 52966 Job CP sec= 132.734
Factor Done= 50% Factor Wall sec= 4.373 rate= 9224.3 Mflops
*** WARNING *** CP = 141.156 TIME= 17:36:18
proceed in the in-core memory mode. The Distributed Sparse Matrix
Solver will now restart using the out-of-core memory mode.
Local memory allocated for solver = 273.905 MB
Local memory required for in-core solution = 471.939 MB
Local memory required for out-of-core solution = 173.117 MB
Total memory allocated for solver = 1026.165 MB
Total memory required for in-core solution = 1816.210 MB
Total memory required for out-of-core solution = 556.887 MB
*** WARNING *** CP = 142.172 TIME= 17:36:19
out-of-core memory mode. This memory mode may provide significantly
worse performance compared to the in-core memory mode, depending on
the amount of available system memory and I/O speed. Please monitor
the solver performance to ensure that the large amount of I/O to the
solver files does not create a bottleneck for performance.
curEqn= 44340 totEqn= 57705 Job CP sec= 156.797
Factor Done= 111% Factor Wall sec= 29.041 rate= 2692.6 Mflops
solver = 203 MB.
Processor Model: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Compiler: Intel(R) FORTRAN Compiler Version 17.0.4
Intel(R) C/C++ Compiler Version 17.0.4
Intel(R) Math Kernel Library Version 2017
Number of machines requested : 1
Total number of cores available : 8
Number of physical cores available : 4
Number of processes requested : 4
Number of threads per process requested : 1
Total number of cores requested : 4 (Distributed Memory Parallel)
Latency time from master to core 1 = 2.041 microseconds
Latency time from master to core 2 = 2.061 microseconds
Latency time from master to core 3 = 2.172 microseconds
Communication speed from master to core 1 = 5823.39 MB/sec
Communication speed from master to core 2 = 5931.61 MB/sec
Communication speed from master to core 3 = 5570.48 MB/sec
Total CPU time for main thread : 154.7 seconds
Total CPU time summed for all threads : 157.6 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.8 seconds
Elapsed time spent solution - preprocessing : 5.0 seconds
Elapsed time spent computing solution : 148.9 seconds
Elapsed time spent solution - postprocessing : 0.1 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Equation solver used : Sparse (symmetric)
Maximum total memory used : 3817.0 MB
Maximum total memory allocated : 7925.0 MB
Total physical memory available : 16 GB
Total amount of I/O written to disk : 1.5 GB
Total amount of I/O read from disk : 0.4 GB
Don't you think this would have more traction in the actual ANSYS forum?
forum569
After you re-post, you should delete this thread to avoid duplicate threads
TTFN (ta ta for now)
