ElCidCampeador
- May 14, 2015
- 269
would like to know thermal calculation for a thermal oil heater like this one:
Is there a simplified method to calculate the surface temperature of the outside wall of the coil? What parameters are necessary to know? Flame temperature?
Coil material is carbon steel.
Thank you
Thermal Oil Heater - by AB&CO
AB&CO thermal oil heaters are designed for process heating systems. The boiler ensures you safe circulating heat transfer fluid (HTF) up to 400°C and 10 MW.
www.abco.dk
Thank you
