I am calculating the stiffness of the substructure elements and bearings to determine the thermal point of origin (TPO) on a continuous steel bridge. How do I determine which supports to make fixed supports? Is it just the support closest to the TPO? The supports to the left and right of the TPO? Do I need to adjust the stiffness calcs depending on which support/s I make fixed? Does the TPO just become the location of the fixed support?
