Hi all,
What is the design considerations regarding the punching force on a SCH 40 pipe with a thin wall thickness(0.15in) when welding a thicker plate (3/8in)? AISC has lots of design information on round HSS, but not pipe. Can I apply the same connection design concept to pipe? Does the maximum plate thickness formula(AISC Manual K1-3)applicable to a pipe?
I am also looking for an example of this design. Thank you.
