Thread Form Decode (Oil and Gas stuff)
Pud
GB
I need to draw up a threaded protection cap for one of our customers.
Being oil industry stuff, they all seem to use "home made" thread forms ( I think)
The thread is designated:
6.11/16" - 5NA - 2G (STD)
Major Dia 6.688/6.788
My question is: what is the pitch?
Sorry to be thick - I usually just get a part off them and measure it, but they have none at present and I want to get on with the cap design,
Cheers
Harry
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
Hi Bill,
No. it's not a drill pipe thread - the part description is:
Integral Pupjoint - 15K CWP
Is this a "closed" forum? I can upload the drg if it is...
Cheers
Harry
Pud,
That appears to be a thread callout per the U.S. (inch) ACME thread standard. "Pitch" is 5 threads/inch, in National Acme thread form, with 2G thread tolerances.
Some more info. here
you can get a copy of the standard, if you need one, from
Machinery's Handbook should list all the info. that a competent machinist would need to cut the thread.
Cheers guys - I get it now. It was the 5NA - especially the NA bit I am unfamiliar with. (Although I do know of Acme threads!!)
LPSs all round!!
Harry
Glad to help, Harry - I finally get a chance to pay back some of your priceless advice from over the years.
Should be interchangeable with the old BS ACME threads from what I recall Pud.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
