  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Thread Notes 2
UKIDIOT
36
How do I change the format of a thread note callout? I looked in the help guide, and it said that you have to change it in the callout_not configuration. But I didn't see a option for that in the config. options. Is there any easier way to do this or am I just missing the option?
ukidiot,
You can modify your thread call-outs to contain as much, or as little info. as you like. You need to copy and modify the .hol files. The trick here is the syntax. Here is a link to a PTC article that clarifies the mystery.
J.W.
ttx,
Could you give me a basic idea of how to do it. Or is there another website that has the information posted? Thanks, alot for the help.
UKIDIOT,
Here are the critical steps and (2) examples......
1)Locate the .hol files that are stored in Pro/E.
2)Make copies of the files that you want to change. It is best to make copies and leave the originals intact.
3)Place the new files in a folder of your choice.
4)Change your config.pro file to look for these files.
(hole_parameter_file_path)
5)Modify the .hol file line "CALLOUT_FORMAT". (see below)
6)Modify "THREAD_SERIES" to a custom name of your choice. This new name will appear in the hole creation dialogue box.
I have included below, the header from one of our .hol files. As I have said, the syntax is critical. The spaces between characters must be exactly right.
TABLE_DATA
PRO_VERSION 22
THREAD_SERIES ISO2
CLASS H
TABLE_UNITS metric
DEPTH_RATIO 1.25
CALLOUT_FORMAT &Metric_Size TAP <CTRL-a>x<CTRL-b> &Thread_Depth
On a drawing, this will read.....
MX x X.X TAP (depth symbol) X.XX
Here is an exerpt from PTC...
EXAMPLE: The syntax for the default UNC callout format would appear in
this way (all on a single line) in the .hol file
CALLOUT_FORMAT &Screw_Size &Thread_Series - &Thread_Class TAP <CTRL-a>x<CTRL-b> &Thread_Depth / &Number_Size DRILL ( &Diameter ) <CTRL-a>x<CTRL-b> &Drill_Depth - ( &Pattern_No ) HOLE
NOTE: <CTRL-a>x<CTRL-b> must be typed in exactly as shown. "CTRL",
here, does not refer to the control key on a computer keyboard.
One final note.
You have to restart Pro/E each time to see the changes.
Best of luck,
J.W.
Thanks, alot for the help. I just another question though. I'm looking to change the callout from a single line to a multiline format. To look something like this:
5/8-11 UNC - 2B TAP (depth symbol).400
(diameter symbol).531 (depth symbol).500
Is there anywhere I can get a list of built in parameters with Wildfire 2. Also what are the <ctrl-a> and <ctrl-b>?
Thanks.
UKIDIOT,
The note that you want should not be a problem.
Sorry, I do not have any experience with Wildfire though.
As for the syntax....
In my example, I believe that "x" is the depth symbol and
<CTRL-a> and <CTRL-b> are just the characters that Pro/E needs in order to display the depth symbol. Somebody who is more into programming may be able to explain it better.
Anyways....
I believe that; <CTRL-a>v<CTRL-a> gives you a counterbore symbol and that <CTRL-a>n<CTRL-b> gives you the diameter symbol.
If I remember correctly (3) spaces forces the text to the next line....or something like that.
JW
Hi guys,
Great post, is there a way to control the # of decimal points for the depth of threads and root drill depth?
What would be the PCD (Pitch centre diameter) syntax?
Tofflemire
Tofflemire,
The only way that I have managed to effectively control the number of decimal places for 2001 is this....
1.While in drawing mode, select FORMAT>DECIMAL PLACES - then choose your desired value.
2. Now go back to your model and select FEATURE>REDEFINE.
When the hole dialogue box pops up - hit the check mark.
3. Now go back to the drawing and reset the number of decimal places to the default or your usual number for general dimensioning.
I don't know whether or not this is a bug however, with the build that we are using, this is the only way we can get the parametric thread and hole notes to behave properly-and not reset to x.xxx after regeneration.
As for the PCD syntax - good question....
cheers,
JW
