thread
Santa123
80
PL
Hej,
I have a shaft with Metric Thick Pitch, and when I change shaft diameter I lost Laterar Face all the time.
Best Regards
Santa123
Hi! Santa,
Normally this shouldn't happen. When you change the shaft diameter, it asks for an update in the Thread feature, which you should update according to the diameter you changed in the shaft.
The Lateral (Cylindical) face should not be lost. I am not sure what is the exact problem.
Himanshu
