thread561-290743@FrankSwinks: I stu
CadGuy59
Computer
Aug 29, 2008
16
thread561-290743@FrankSwinks: I stumbled across this utility to export parasolids from an assembly. Super nice tool but I'm finding that it doesn't export all components of my TC based assembly and I can't seem to figure out why. Any thoughts? I made sure all components were fully loaded and it appears to only export 8 of my 10 components.
TIA,
Bob
RJ
NX 12, Teamcenter 11, Windows 10
Make sure your assembly is fully (not partially) loaded.
Jerry J.
UGV5-NX1899
Please re-read my post...
RJ
The journal will ignore all bodies in components that are hidden, suppressed, or on a layer that is turned off. Please check that the component visibility matches that of the occurrence body. It is possible that the body is visible in the graphics area, but the component is "hidden".
www.nxjournaling.com
Do you have a mix of Metric and inch components in your assembly? This will cause us issues exporting stp files. Do not know if this is the same.
All components are visible, no hidden geometry, all layers selectable and components are fully loaded. Puzzling for sure.
RJ
Could those components be something ROUTING was used to create, and be a SPACE CLAIM ? I do not think those can be exported.
Jerry J.
UGV5-NX1899
The journal only looks for solid bodies; sheet bodies won't be exported. Also, solid bodies that fail the important examine geometry checks may not behave as solid bodies.
faq561-2116
The "non exported" , are these bodies lightweight or convergent or faceted ?
Tomas
The more you know about a subject, the more you know how little you know about that subject.
