dodson
- Dec 1, 2006
- 11
I have a Timber space truss that is using a combination of steel pipes and rods as the compression and tension members. The contractor wants to use turnbuckles on the rods for erection purposes to be able to rack and plumb the truss, but the architect doesn't like the look of turnbuckles. One idea has been to take a pipe section and thread the inside to act as a turnbuckle. The rods are 1 3/4" diameter. I was thinking about using a 2"-XX pipe, which has plenty of tensile strength (max tension is 35 kips) and an inside diameter of 1 1/2". My question is how to calculate the strength of the threaded section on a pipe?
