I have a question that came up the other day when we were putting tie breakers between 2 480V switchboards. We have a 2 5kV breakers each feeds a different 4160-480V Delta-Wye transformer. These transformers each feed a separate switchboard with breakers. We tied these switchboards together with a tie breaker on each to backfeed if one of the transformers were lost. My question comes here; we measured voltage between the 2 switchboards and measured A-A 280V B-B 280V C-C 280V. This must be coming from the transformer having differing polarity as the voltage between A-A B-B C-C should be 0 to avoid closing into a bolted fault. Can someone explain how 280V is developed?
-Thanks
-Thanks
