pelelo
Geotechnical
- Aug 10, 2009
- 357
Engineers,
I am working on the design of a platform using timber piles. I got few questions:
1 - For lateral analyses, i plan to use LPILE. LPILe doesn't offer the timber pile option, however there is a option called "Elastic Section (non-yielding)" (see attached). Do you think that is the appropriate way to perform lateral analyses on timber piles?
2 - For checking deflection. Is there a maximum deflection specified for lateral analyses in timber piles?, I know for my concrete piles i limit lateral deflection to a max of 1 inch however, i think 1 inch for timber might be too high. Any thoughts?
3 - Refer to the lateral analysis attached that i performed. The depth of the pile would based on which ever is deeper between the bending moment and the deflection diagrams, correct?. Please let me know your thoughts. When i perform analyses on concrete piles, i don't that the "equilibrium" in the deflection chart is that deep, therefore most of the time the depths are based on the bending Moment chart.
The application of these timber piles is to support a walking platform. Water will be 1 ft below top of the platform, so essentially the piles are going to be submerged. Soils in the top 10 feet are composed of loose sands. Between 10 and 20, soils are medium sands.
Please advise.
Please advise.
