  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Time history analysis of a shutting down pump located on a concrete platform using SAP2000
Math-B
Hi, I was wondering if any one has an idea about how to use SAP2000 time history options for entering time vs variable forces of a shutting down pump located on a concrete platform.
The nature of the load is varying (decreasing) with time but has a form of rotating machine and components in vertical and horizontal directions that are descending with the time.
Math-B
I'm not quite following what the loading function is.
If the function isn't a sine, ramp, etc., then you could consider defining the function in a spreadsheet, exporting to a text file, and importing into SAP2000. To define the function, go to "Define Time History Functions," and add a "From File" function. Then use this function when you define the time history load case.
I hope that helps.
Thanks for the response and useful function.
Math-B
