It seems that my previous post has been deleted from the message board; so here's my repost with a few more details.
What I'm trying to do it trigger a relay (from closed to open) for a variable amount of time.
The start trigger is going to be a momentary switch (mercury switch). When depressed, I need a timer (555?) to open the relay for a specific amount of time, at which point it will revert to being closed again. The times will be from 10ms to as much as 1s.
If the switch is still depressed at the end of the timer sequence, I'd like to leave the relay open and reset the timer and start again.
The whole thing needs to run off a DC power supply between 11-15 volts (maybe a little more...) and hopefully the timer should not be affect by the voltage too significantly.
As I mentioned before, I not very much of a hardware kind of guy; I'm more the programmer type. However I think this circut might be very useful for many people.
Any help would be appreciated. I'd like to get something basic going at first and then build on it as I learn more.
Thanks very much!
Nicholas
erkware@yahoo.com
Thanks very much!
Nicholas
erkware@yahoo.com
