mechengineer
Hello everyone,
Whether it allows to use VIII-2 part 4.5 instead of VIII-1 UG-37 by code?
My understanding is that should be no problem for the re-pad with full penetration & full UT or the integrally reinforced opening with full UT (no cyclic load).
The case is that DP=23 bar, DT=80 deg. C, material: SA516Gr70, SA106B, shell ID=1150, 12" nozzle CL300. Re-pad is not allowed as sour service (DP=10 bar only). If use VIII-2, part 4.5 the reinforcement area is sufficient with sch.120 and the shell thickness of 15.88 mm, but if as per UG-37 the nozzle has to use a forging neck (40 mm thk.) for this nozzle even LWN (35 mm thk.) can't be used.
I prefer to use VIII-2 part 4.5 or Appendix 1-10 of ASME VIII-1 for this nozzle. However code does not clearly indicate allows to use VIII-2 part 4.5 instead of VIII-1 UG-37 and moved Appendix 1-10 of ASME VIII-1 to VIII-2 part 4.5, which give a impression that seems Appendix 1-10 is not applicable for ASME VIII-1 PV design. This feedback is from is a lot of engineers and clients.
Welcome to share your idea here. Thank you.
