Hey all,
I am modelling tension leg platform of which column, tendon and two pontoons are connected at each corner. My major challenge is the Connector that I can use to effectively connect all my nodes since the available connectors only connect node to node and not multiple nodes, even MPC also connects only node to node. If I connect node to node, my system will still not join perfectly. Any tip on this will be appreciated.
Thanks.
Dam.
Thanks.
Dam.
