mechengineer
- Apr 19, 2001
- 268
Whenever the calculated stresses based on the nozzle loads in specification exceed the allowable stresses, the actual nozzle loadings to be provide for re-checking. If increase the whole shell thickness due to the nozzles load, the user/client approval for acceptance is required.
In principle, a user would not allow to increase the whole shell thickness due to the nozzle load that you can identify by the fact that the shell thickness somewhere is thicker, somewhere is smaller. An user shall assess and balance the cost if reduce the piping load from piping side (like add piping support…..) to avoid piping engineer throw the problem to PV manufacturer and increase the cost for the pressure vessel due to the nozzle load. EPC may not be care for such case if it does not exceed the project budget.
