Of course humidity can be measured by a variety of instruments.
Otherwise, if you wish to estimate it, assuming perfect and complete combustion with excess (xs) air, knowing the % CO
2 on a dry basis you obtain y/x (i.e., the H/C atomic ratio) of your fuel in C
xH
y.
Since the volumes of CO
2 and H
2O aren't affected by xs air, and the volume of water from combustion is equal to (y/2x) times the vol of CO
2, one can estimate the volume of combustion water from that ratio.
For example, assume one is burning a hydrocarbon fuel with 20% xs air (about 3.5% oxygen in the flue gases) and measures 11% CO
2 on a dry basis, it would result in y/x=2.9 (a typical refinery gas). And y/2x=1.45, meaning water volume would be 1.45*11=15.95. Added to 100% dry gas results in 115.95 volumes of wet gas, and any % expressed on a dry basis should be divided by 1.1595 to get the % on a wet basis.
BTW, the xs air on a perfect and complete combustion of a hydrocarbon can be determined just by knowing the % O
2 with little appreciable error for any hydrocarbon fuel, as follows:
1% oxygen ~ 5% xs air; 2%, ~10% xs air; 3.5%, ~20% xs air; 5%, ~30% xs air, etc.
Don't forget that any fuel oil atomizing steam would have to be accounted for. I sincerely hope to be understood.
![[smile] [smile] [smile]](/data/assets/smilies/smile.gif)
