todays date journal
moog3
Marine/Ocean
AU
I've had this journal for years, and it's served me well.
It has options in the code for different output formats.
I now need it to output the date as 20/12/2022 which would be option (1) in the code
but....... it doesn't change the output from the option (2) which I've always used
Can someone help fix it?
' NX 4.0.0.25
' Journal created by Henry on Tue Mar 21 10:57:55 2006 FLE Standard Time
'TimeNoteString(1) writes 04.05.2007
'TimeNoteString(2) writes 07.06.07
'TimeNoteString(3) writes xxx
'TimeNoteString(4) writes 7. juuni 2007. a.
'TimeNoteString(5) writes 2007-06-07
'TimeNoteString(6) writes neljapäev, 7. juuni 2007
'TimeNoteString(7) writes 07. juuni 2007. a. 22:44
'TimeNoteString(8) writes 7. juuni 2007. a. 22:47
'TimeNoteString(9) writes 07. juuni 2007. a. 22:47
'TimeNoteString(10) writes 07. juuni 2007. a. 22:48
'TimeNoteString(11) writes neljapäev, 7. juuni 2007 22:48
'TimeNoteString(12) writes neljapäev, 7. juuni 2007 22:49
'TimeNoteString(13) writes 7. juuni 2007. a. 22:49:22
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Properties")
Dim TimeNote As DateTime
TimeNote = System.DateTime.Now()
Dim TimeNoteString as String() = TimeNote.GetDateTimeFormats()
workPart.SetAttribute("DATE", TimeNoteString(2))
'change the number in the line above to suit your format
End Sub
End Module
Cowski,
I'm a real hack at this..... i read the article, and just played with it, eventually i got it to work with this line..
workPart.SetAttribute("DATE", TimeNoteString(0))
