Does anyone know which is the permissible tolerances for MVR to ensure that the material is not degraded during the injection process?
I know that the values of MVR is influenced by process conditions, humidity of polymers and storage.
How can evaluate the degradation level of material using the MVR values?
Which should be the difference between raw material and injected part regarding MVR?
If the specification is 15÷40 cm3/10min and I found 46, can I say that the material is degraded?
Is a 50% increase is too much for a molded part compared to raw material?
Thank you!
Thank you!
