Hello all...
Im running Sworks 2004 SP0.
Issue:
Two people are working on one common assembly. I finish some work on the assembly, add a few nuts and bolts via the toolbox browser, then I pass the assembly over to my partner so he can do some of his work to the assembly. He opens the assembly and all the hardware (nuts & bolts) have gone SUPERSIZED. Right click the bolt and edit toolbox definition, and the proper size bolt is listed but shows up 10x larger then actual. (ex 1/4-28 looks like 3")
Two different computers, both WinXP, both Sworks 2004 SP0
We do have a mix of metric and english hardware in the assembly. Will that matter??
Anyone know why the hardware is not being loaded properly?
or a possible fix.
Thanks alot....
Travis.C
Mech-Eng
Issue:
or a possible fix.
Thanks alot....
Travis.C
Mech-Eng
