miked64
- Mar 28, 2012
- 80
I have a cnc jig mill that requires manual tool changes. I would like to have a tool retract to its home postion turn of spindle, coolant ect. the same as getting ready
for a tool change but use the same tool right away and have it pick up same h comps, ect. the reason being a air index table is being used so the operator
has to rotate that manually as well. The only way i can force that is with a different tool number, thats not what I want, I want to keep the same tool in the spindle.
