I think it's fine, but I'd add blocking between the joists for the issues that lexpatrie mentioned. Also, this possibly isn't an option, but can you make the stud shorter so the joist bears on that? It's a slightly more solid connection (direct bearing joist to stud instead of hanger, less chance of splitting/checking at the notch) and you can still notch the end for the eave.
