frankieh
Chemical
- Apr 4, 2008
- 11
Does somebody knwo how the TOL corrosion can be calculated in pipelines or does somebody have references to acticles on the web.
I found 1 article from the NACE titled: "Top of Line corrosion and water condensation rates in wet gas pipelines"
In this article it is explained how to calculate the TOL corrosion rate based on the FE++ solubility which is dependent of CO2 pressure and temperature. If you know how to calculate the Fe++ concentration or know a good/cheap program which can do the job, please let me know.
Regards Frank
Regards Frank
