Stefan2211
Chemical
- Jun 25, 2020
- 104
Dear All,
I am still looking for a correct answer, which I couldn't find in google, nor from the heat exchanger supplier. I found a lot about "hot bolting" but nothing about the torque required for bolts in hot environment like the flange connection of a floating head.
We have a high temperature heat exchanger with floating head. The shell side is operated at 275 Deg C, tube side is 200 Deg C.
So the bolts of the floating head are actually exposed to 275 Deg C.
Mu assumption is, that the torque of these bolts should be higher than the normal torque since the bolts expand under the high temperature. This is different to bolts outside at the main head.
Supplier refers to ASME PCC-1 ( we do not have it) but admits it is not covering this subject and we should just use the standard torque for the bolt.
Anyone can briefly comment on this?
Thanks a lot guys
Thanks a lot guys
