DALOB
- Jul 14, 2005
- 3
I am trying to work out the torque required at a shaft so I can size a gearbox.
My shaft is connected to a sprocket of 260mm dia.
The force applied to the sprocket due to a chain is 340kN (this is the summation of all of the resistances)
The diameter of the shaft to which I will be attaching a gearbox is 125mm
The chain is running at 0.5m/s (it provide the require material throughput)
The calculated power required is 198kW (based on required F and velocity)
Now I know Torque = F*r. Can I state that the required torque is simply the torque from 340kN * 0.13m = 44kNm and therefore the tangential force at the shaft is 680kN
Jason
Jason
