ReliaEng2008
I am trying to find how to calculate bolt stresses and torque values for body flanges (joining a heat exchanger channel to a shell, for example) of ASME BPVC Section VIII Div. 1 pressure vessels. There is not a lot of information out there compared to piping.
Checking ASME BPVC Section VIII Div 1., the bolt stress used in the calculations for flanges in Mandatory Appendix 2 comes from ASME BPVC Section II Part D, Table 3. For a SA-193 B7 bolt, for example, the stress is only 25,000 psi (which results in very low torque values in my opinion). But those calculations (the ones that use 25,000 psi for bolt stress) are only to find the minimum amount of bolting required under the rules (this is stated in Nonmandatory Appendix S, 3rd paragraph).
I got some recommendations from engineers to use bolt stress equals 60% of material yield strength (for SA-193 B7: 105,000 psi at 100F - use 63,000 psi). Someone else mentioned to use "w" from equation (5) in Nonmandatory Appendix 2.
Does anyone have experience with calculating torque values for pressure vessel flanges who can help me out?
