Torque_reg
GParta
IN
Hi everybody
I would be grateful if someone could tell how I should input a torque as a function of time. The data runs around 400 samples.
I actually used akspline. But the input time in spline data is 4 seconds and after simulating for 4 seconds my arm is rotating 4 times.
What shall I do?
Thanks for help
ADAMS is quite a difficult environment to use. Hence those of us that are pretty good at it are quite good at resolving puzzles. But I must confess the information in your question resembles less a puzzle than a random hodgepodge of information. The only useful thing I can say is that akispl is a typical approach for reading excitation forces in.
Cheers
Greg Locock
Thanks for the suggestion Greg. The main aim is to input torque( function of time). In this project I'm mainly applying a revolute joint between the two arms and the motion described is AKISPL(Time,0,.world.Spline_1,0). Is this right? The time in the code is making it run only for 1 second instead for 4 seconds.
OK, from this I deduce you are using ADAMS/VIEW rather than the many other ADAMS products, many of which do not use that scripting language. Where is the Time signal specified? what does the final 0 do?
Cheers
Greg Locock
