torsion
wjtin
1
calculation for torsion for column and beam. it's a cantilever beam connect to the column. how to check whether the column can support the cantilever beam or not.
The question is poorly formulated. It makes it look like you haven't made a fair attempt on your own to solve the problem before going to the forum.
Tunalover
wjtin,
as the friend above suggests the problem is poorly defined. Could you give more details on what the situation is and what exactly you want to find?
Dr ADK
It has become appallingly obvious that our technology has exceeded our humanity
- Albert Einstein
